blazerbones
I just hooked up my headlamp relays in my burb. Cool mod.
I want my low beams to stay on when I activate my high beams (factory switch shuts them off while simultaneously turning on high beams).
Thinking that the easiest way would be to jump the "signal" lines (factory headlamp power wires) that activate the new relays and put a diode in between that inhibites current flow from low beam activator line to high beam activator line.
That should be easier/cleaner than adding a 3rd relay to kick on the low beams when the high beams turn on.
Anybody think of a better idea... or try this before?
Someone who understands solid state!
