mill5471
Got an 85' 1 ton 2wd 2 door with the 6.2 diesel. It had been sitting for about 10 years and i got it out and running for the most part. My problem is i have no headlights, all the marker lights, tail lights, and parking lights work, but no headlights. I have replaced the on/off pull switch in the cab and cleaned all the connections and grounds. I have also tested the headlights by connecting them directly to a 12v power source to see if they work, which they do. I have power to the switch and coming out of the switch but not at the headlights. All the fuses are good, is there something i am missing, fusable link or something? If it may be a fusable link where would it be located? Thank you for any suggestions, im kinda stumped.
