chevy_cr250
Registered Member
I have a 1988 Chevrolet k5 blazer it had a rod knock so I pulled the motor and found out it was a 307 out of a 69 Camaro bored .30 over so I sold that and got a 350 out of an 86 Chevy truck, cleaned it up put it in everything is good and working good except now my headlights/daylights and interior lights don't work they did before the swap. I replaced the switch and the 2-30amp circuit breakers and cleaned up all the grounds I could find and nothing. My turn signals and hazards work fine but no dash no dome no headlights/daylights. Any help would be greatly appreciated I am half tempted to just replace the entire wiring harness (PO spliced wires cut wires etc) and My turn signal switch smokes when I use the washer fluid. Any help and pointers would be greatly appreciated this was my first motor swap I've done many trans.
Matt
Matt
