mudbuggy
I've been dreading this day for a while now, but here it is and it needs done so I started this afternoon. Whoever said that it was just a couple of hours to do, they're crazy, well maybe just the headliner but I guess you could say that I don't like having to do **** twice, so I decided to insulate the roof section at the same time.
When I first got the truck, 89 gmc v1500, the first thing I did when I got it home was to seal up the front headliner with duct tape and to pull the rear headliner and pull the rear carpet. I don't know what I was thinking, I could have been cleaning the old board a little at a time, like I said earlier, I fell into the hipe of 'oh it only takes a couple of hours', yea! I've got 4 hours in cleaning the crap off of the old board now but I also wanted to get rid of all of the old glue and foam too. I worked on the board for 15-20 minutes, then switched over to cuting foam board, then switched to cleaning and painting plastic, then back to the board, then, well you get the idea. I guess I want to make sure that the rear sticks in place since there isn't anything that is in the middle of the rear like the front headliner, so I went for it. I got the material from a fabric store Friday, and got some stuff to seal up the front cab from the rear since I only have the front ac working right now. The cheapest I could get the lines that go to the rear ac was $600, so I decided to just by the tools that compress the fittings on the line. I'm glad that I did too, before I began making lines I tore out the rear ac system to go through it completely, and not having to look up to do it. I've been trying to source the lower housing for almost 4 months now with no luck. I'm almost to the point where I'll just make the lower and upper housings out of aluminum and be done with them, never having to worry about how tight I am making the screws or am I breaking the plastic making it to tight. Don't really like the idea of all of that weight being supported by 25 year old plastic anyway, especially after I charge the system with almost 6 pounds of freon, then have to loose it because the rear ac came crashing down to the bed. Nope I think I'll go with plan B. Anyways here some pictures of my day of frustration and fun in 100 degree weather.
you're almost there. One of those big jobs you don't enjoy that have to be done sooner or later.. at least it will be off the list soon
