Not sure a vacuum gauge is necessary for this job, but as huge tool whore I am not going to discourage anyone from getting tools.
Unless you have a huge rumpty rump cam your engine will make enough vacuum.
Need to inspect all the vacuum lines. There should be a plastic ball with 2 vacuum line connections, near the windshield wiper motor on your truck.
1 hose from manifold vacuum, below throttle blades, to ball. From ball to in Dash controls.
Sometimes you will find a check valve in the source hose to ball. It isn't necessary if it is gone. Check valve is useful if you are wide open climbing long hills.
