Edit: Just be real carful with your little girls around them. In a garage I'd try to make some sort of base that the propane cylinder sits into to keep it from tipping over so easily.
I've been thinking about getting one of these too. How often do you have to fill the tank?I've been heating my 2 car garage for years with that dual burner Mr. Heater at the top... use it on a 30 lb bottle, works awesome.... matter of fact, I just fired it up 5 minutes ago!![]()
I can't calculate how many hours but, it will last you quite a long time.
I get about 25 hrs out of a 30 lb'er.....
i bought that mr heater at a swap meet like 15 yrs ago for $10!!!![]()
I just did a seachtempest for one in my area, no luck
Is your garage insulated? Mine's insulated in the walls but not the ceiling. It's an attached garage, so one wall is part of the house, obviously. Even with no heat it never gets freezing in there. I've had a shallow tray of water out there all winter and it has never froze. Not even in the dead cold of night.I get about 25 hrs out of a 30 lb'er.....
