I have a 74' blazer with a 350sb, quadrajet, long tube headers, dual exhaust both to the rear. New radiator, t-state. Possibility running a little lean.
The problem i'm having is what I call vapor lock. It runs fine when outside temps are cool but when they heat up its like its starving for fuel or the fuel won't push through to the carb. I know because I have a clear fuel filter just before the carb so I can see whats going on. (No fuel in the filter when hot but will idle all day long on no fuel).
What I have done is install new mechanical pump. (still the same). Install an electric pump at the tank in conjunction with the mechanical. (same thing). Remove the mechanical pump, reroute the fuel line to the outside of the frame rail. (STILL THE SAME THING).
So whats next?
1)Stock manifolds to single exhaust down drivers side?
2)Shortie headers (center dump or similar) to single exhaust down driver side?
3)Long tube headers to single exhaust down driver side. (seems like this would be a pain in the ass to make work.
Any suggestion, ideas, parts and part numbers you have would be greatly appreciated.
Thanks,
Brian
So whats next?
Thanks,
Brian
