Jessie James
So I have a 91 K5, TBI, CA truck that has the emissions pump removed, and headers installed. The O2 sensor was not upgraded with the headers, so it always ran way too rich.
I bought a heated O2 sensor (can't remember which one, but it was the same as someone else here bought) and installed it carefully. No silicon got on the sensor. I wired up to 12v+ on the fuel pump relay. I used an OEM style quick-disconnect connector, and a wire tap to connect the O2 sensor signal wire to the harness sensor wire (not soldered).
When I first started my truck, it immediately started up, unlike previously where it would take 3-5 seconds, so that was good. It idles absolutely perfectly. And for the first 5 minutes of driving, it's absolutely perfect.
However ... once it gets warmed up the engine starts missing like crazy. It has to be missing on 4 or more cylinders. I am pretty sure it's running too lean because the smell coming out of the exhaust is a scorched burning smell.
What did I do wrong? Is there a specific heated O2 sensor I should be using? Have to reset the ECM?
Any help would be greatly appreciated.
