bmooredeer
Newbie
Hi CK5 Community!
I have 89 Jimmy and have been experiencing some issues with the heater and blower motor.......long story short I replaced the blower motor 4 times in the last month. Original replacement was dead out of the box, second motor worked for a week, and 3rd replacement was dead out of the box - 4th time the charm?
The first three motors were all the same model/brand/serial numbers which I'm assuming were on the same shipment from China - 4th was from Napa and a bit different.
Now that I have the 4th motor installed and running there is no air blowing from the vents but the motor is pushing air on all 4 speeds. I removed the glovebox and duct behind it which got me into the bowels of the dash. There are two damper doors in the dash-
***The door connected to the hot/cold lever on the dash assembly seems to work great and controls the damper door set farther back closer to the blower motor and heater core.
***The door directly behind the duct I removed inside the glove box (some post refer to this as the "mode" door) seems to not be working correctly. There is a little white piece of plastic that is broken on this door which I will replace (saw this on some other threads) but my bigger question is-
What controls this mode door? It doesn't appear to me that fixing this broken plastic piece will correct the problem - should there be some sort of linkage from the actuator above this door to the other "damper" door cable??
Is this vacuum controlled? One item to note, when I replaced the blower motor there is a small cooling tube about 4 inches long that would not reach the outlet on the new motor so I plugged it - as a check with the heater running on high I connected a small vacuum to where this went into the heater duct and it did not make the air blow any harder.
Sorry for the long message - this is my first post here and I'm hoping to get this fixed once and for all!!! Thank you!
