Wanted Heater control, radio delete, tachometer for 81 k-20
Vombrown
Mountain Man
Great Falls mt
My heater control unit is falling apart, Looking for one in good shape. Aftermarket tachometer, just a small one don't need a 5" tach. And a radio delete plate. Some idiot cut a big hole in the dash for an old 90's GM head unit and I guess I'll just put a radio in there....somehow.
gm factory radio delete plate is not much bigger than the factory hole . just a fyi .
Yeah the hole they cut isn't in the cluster it's over in the actual dash to the right of the cluster. More where factory AC vents should be. I'm going to install some sort of double DIN radio to use the hole they cut and just delete the factory radio position.
I have the radio delete plate from my CUCV. And a small aftermarket tachometer. And I also have a spare AC-equipped HVAC control panel (which style are you needing?).
What are they worth to you?
I can use the radio delete and the tach but the heater control I need is the heat only cable version. I have one of the AC control panels and it wouldn't work. On the other two, hell I don't know. Give me some idea on what you want for them.
I'll get you some pictures first, but how 'bout I mail the tach & the radio cover, and you mail that valve cover + $20. Is that fair?
Sounds good to me. I'll get it boxed up and just toss a money order in the box for ya.
Pm me your address again,
