Looking for:
- Aftermarket Tachometer
- Non-AC Heater controls (cable type)
Think I have seat belt and a gauge cluster from a K20. If that mattersLooking for:
- 600ish cfm Holley Carb, single fuel inlet preferred.
- Seatbelts for a 73-87 K10 pickup
- tachometer
- gauge pod
What color are the belts and do they retract and lock? Also not looking for a gauge cluster, just one of those aftermarket gauge pods.Think I have seat belt and a gauge cluster from a K20. If that matters
Exactly what I'm looking for, PM sentit was rebuilt and put in the drawer its a 600 cfm, is this what your looking for?
What are you looking for in a pod? What gauges? Think I might have couple. Just have to find them.What color are the belts and do they retract and lock? Also not looking for a gauge cluster, just one of those aftermarket gauge pods.
So I was messing around with the truck in question today and actually the factory gauges are working except for the coolant temp. It seems that I just need to replace the sending unit and trace the wire, so I guess I don't really need any extra gauges other than a tachometer if you have one laying around.What are you looking for in a pod? What gauges? Think I might have couple. Just have to find them.
Ok. No problem.So I was messing around with the truck in question today and actually the factory gauges are working except for the coolant temp. It seems that I just need to replace the sending unit and trace the wire, so I guess I don't really need any extra gauges other than a tachometer if you have one laying around.
Oh and it also turns out that I had a spare seat belt hidden in a box of old parts, so it turns out that I don't need that either...![]()
I have a non a/c heater control.Looking for:
I have not found it yet, but I still have a couple of sheds to look in, and if you have seen my sheds you would understand why it takes a long timeBump. Still looking for heater controls
I don't need the belts anymore, they're all yours.If @Chevy305 doesn’t want the belts, I’d be interested pending price. I’ve got some buckets in the second row and the belts are not good enough for my girls. Every time I put them in I am nervous. These wouldn’t be a direct fit, but may be better than the current one s.
