Just thought I'd share my experience with a heater core replacement on a first gen. First there is a great article about this for '75-'91 blazers in the technical section which I used and I only have a few things to note:
-The heater core was $25 at pep boys. About 10 years ago, I had a heater core replaced on a 80 blazer at a shop...this cost me $200 which would probably be more today. Which leads me to the next point...
-It's really only about a 2 hour job on a first gen and is extremely easy even without power tools. Biggest hang-up for me is that it looked like I could get all of the bolts/nuts without moving the fender. After contorting myself to get what looked like the last bolt, I tried to remove the heater core/blower housing. There is definitely one more bolt (on the firewall and close to the right fender) and you do pretty much need to move the fender or cut a hole in it to get at it. I moved the fender by pulling enough bolts to allow it to bend and give me access to the bolt.
-Note that on a first gen, the heater core is in the engine compartment and on later models it is on the car interior side of the firewall.
-Make sure you remove the heater flap cable before pulling the core's housing. You can get at the cable from inside the truck, in the passenger footwell you'll see a cable running through a rubber cover in the heater ducting. Remove this cover and pull the end of the cable off of the heater flap.
-The core housing is removed and the core is attached directly to it with some screws that go into metals straps around the core (you won't see the straps until you pull the housing). Leave these screws attached until you pull the housing.
-On a first gen (at least on my 72) the bottom heater line is 3/4" hose and the top line is 5/8" (or maybe it's just wrong in the tech section).
After looking under my dash today, I found my next project. There is no ducting running up to the top side of the dash. The main duct is made of metal and it looks like these upper heat/defrost ducts must have been plastic or similar. I'll be taking some measurements and off to home depot to see what I can scare up. Looks like maybe a 10 minute job /forums/images/graemlins/smile.gif
