mudbuggy
I have had an issue with the suitcase under the dash for a while. I have finally gotten the ac back together again, but its not cooling off how it should be. So I was wondering about installing a vacuum controlled water switch on the heater hose inlet. Then I started to remember about some of the trucks that we have around the shop have a summer winter valve on the heater core to stop the hot water from going into the heater core while the ac is attempting to cool the truck off.
So I figured I'd see what everybody does when they have less then a factory suitcase under their dash. It does great heat, and allows a lot of heat out even when the ac is on. Mine is an 89 V1500 with the 350. Thanks for the input guys.
