On occation when I turn the heater on in my truck I see the little battery light illuminate ever so slightly. Its only noticable at night. The higher I put the fan the more bright it gets. It does this intermitantly. If I turn off the heater the light goes completely out. Also my volt gauge reads steady up around 15-15.5 volts. What could be causing this? Any ideas?
Wouldn`t hurt to check all your grounds...
