Seeing you replaced just about everything,the wires themselves are the only thing left,and it's possible the mice chewed them ,and may have cut them in two...double check the resistor and see if any power gets to all 3 taps on it...high speed is controlled by the blower relay,the other speeds are controlled by the resistor..
The resistor can "burn up" if the heater box was clogged with mouse nest,it needs the fan blowing on it to keep its temperature within limits..(seen a few trucks burn up when the resistor started the mouse nest on fire before !)..
That mice nest stuff can be deadly to humans,I'd remove it all and use some type of disinfectant to kill any lingering viruses that might be in the heater ducting..sometimes the mice build a nest on the firewall side of the heater box too,not just the other side under the dash--that has to be removed for air to flow thru the heater core--on square body trucks you can usually gain access through the blower motor "hole" and use a shop vac & vaccum up all the crap out of there..to clean the other side may require removal of the heater box under the dash..
You'll have to start at the engine where the vacuum supply comes from the intake manifold,back to the "bowling ball" storage tank,if it has one on the firewall,then into the cab,where the hoses connect to the selector switch,then down to the vacuum cans that operate the flap doors inside the heater box..make sure the hoses aren't cracked or melted anywhere,that vacuum is actually present at the engine source,and after the "ball" thing on the firewall,then go from there--.
