I use two barrel stoves similar to the double barrell one shown in the post above,but I can only use one barrel,my chimmney inlet is too low to allow a second barrel to be placed on top of the lower one,but it still heats quite well--I made that stove by using a kit from a local hardware store that had a kit similar to the ones in Northern Tool catalogs,it gives you the door & legs and pipe outlet..only thing I dislike about the stove is the fact it can burn a whole tree in a day or so trying to keep an uninsulated 20x40 Quonset hut "liveable"..you spend a lot of time hunting for free wood,cutting and splitting it,and waste a lot of time getting the stove going and keeping it going and not let it go out..
I built the other barrel stove so it stands upright ,with a "hatch" on the top to load it,and I put three 2" pipes into the barrel ,one in the "bung" opening and two on the sides to let incoming air in,just like a Tempwood stove--it works very well and the flat top makes cooking or boiling water a lot easier than on the other stove..its appetite for wood is discouraging too though...
I tried a 150K BTU propane heater,but it would not run on a 20 lb cylinder,it would frost up the fuel hose and then it would stink and go out--it also made a lot of condensation on the steel roof arches and drops of water would freeze ,then drip all over you and everything inside when the room warmed up..propane is expensive and a pain to go get every time it ran out,so I decided to sell the heater--I still have a "china mans hat" propane one but it says it needs THREE 100lb cylinders in tandem to supply it with sufficent fuel,so that one will likely never be used again,and I'm missing the hose & regulator for it..
I have a 110K BTU and a 55K BTU torpedo heater that runs on fuel oil ,diesel,or kerosene,but at 3.30 cents a gallon for diesel,and 6+ bucks for kerosene,I dont use them much...but sometimes you want to get heat instantly and not wait an hour for a wood stove to get going good--and I tire of having backdrafts blow smoke back out of the stove when it is windy,which is about every day here,I feel like I am getting CO poisoning some days after I doze off in front of the stove and winds blow smoke back into the room it is in,which is fairly airtight...
There is no good way to heat a garage really,especially if its an uninsulated steel building,but being out of the wind and having it 40 degrees inside feels like Miami compared to this mornings 13 degrees,with 40+ mph wind gusts left over from the "blizzard"...One heater I liked was a Modine propane one that hung from the ceiling,it warmed a 150x150' warehouse a whole winter ,for 300 bucks worth of fuel...condensation was a bit of an issue though,it made tools get rusty and anything metal in the building was always "dewey"...no troubles with that with wood heat,its as dry as a bone!..
I'm having a hard time disposing of my wood stoveashes--the landfill wont accept them,they refused to let me dump them because they contain too many nails & staples from pallets I burnt,that I can score free at many places--I have tried a few ways to separate the nails and metal from the ash,but none work too good,and it is a real health hazard and pain in the butt--much as I hate too,I will likely have to just dump them way out in the woods behind the house--I hate too because I'm still getting flats on my tractor from nails my dad "buried" 25 years ago,that have resurfaced thanks to frost...scrapyards dont want ash either,one place said they would let me dump them in a junk car "once",but after that,tough luck...
I am tempted to buy some coal,and see how that will burn in my stoves,I think they would burn it ok ,and its fairly cheap,at 8 bucks per 100 lb bag...I was impressed by a friends pot belly coal stove,it was lit at 8 am one cold morning,and at 8 pm,he was afraid to leave,as it was still glowing like a neuclear reactor and the shop was about 80 degrees --with the door OPEN!...he claims it'll burn for 24 hours on two shovel fulls,about 25 lbs!...
Despite the ever present danger of having open flames in a garage when you could have gas fumes,paint or carb cleaner in the air,so far I've been lucky,no fires or explosions and I like using the wood stove to force dry things I paint with Rustoleum,it dries rock hard in a few hours,instead of months...
