Heavy Duty Drive Shafts??
pitbulls'n'blazers
Missouri
What drive shaft do you guys think is best and what size? The one's on my K5 look kinda small,and I'm worried that I will be on the trail doing a bit of crawlin' or boggin' and the drive shaft will break or twist.
really want to recommend the search feature to you - it will yield TONS of results on this topic as well as the other threads you've posted up. that being said, i don't know anything about driveshaft tech, so i can't help much. however, i do know this topic has been covered alot.
if its a trail only machine, save your money and consider square shafts... I don't have any pics of mine before install, but...
click for full-size...
maybe you can see them... or maybe I just like to pic whore;)
more info and pics...
-micah
Thanks guys for the feed back,and good idea about the square drive shafts,but my truck is not just a trail machine.Tough lookin' Blazer ya got there.I am going to use that search more so I won't put up the same thing over and over again.:doah:
Thanks again guys!
I would venture to say your stock shafts will be just fine. I have been Rock crawling on mine for 2 years now and haven't even busted a u joint in them.
I do however carry spares for the front and rear. At the cost of High end drivelines, I have no problems running my stock ones and feeling good about it.
