badmix
This is not your average utility trailer. I had this custom made by Dixie Trailers in St Pete. It was built with off roading and durability in mind. This got used ONCE. An atv trip to Tn and back. My plans have changed and I dont have the ATV any more.
Frame is thick 2" x 3" square tubing.
Asking $900 with the hitch setup , $800 without. Not looking for any trades at the moment, trailer taking up space and HOA hassling me about it.
It has a deck space of 4' x 8' , it has built in spare tire holder with plenty of deck space in front for generator, propane tanks or cargo boxes.
It has all LED lighting, thru the frame wires. It is currently tagged and registered.
It has 2000lb spring with Pro-comp off road shocks, it has 6 bolt GM bolt pattern using GM rally rims with brand new 31 x 8 x 15 tires. The axles are 3500lb.
I have progressive build pics for the new owner, from the fab work, to primer, to paint to final product.
Receiver area is 2" channel. I have a special "TREG" hitch setup. This allows full articulation of the trailer and tow vehicle.
Pic of the truck side of hitch. It allows 360* rotation, 180 up / down and 180 left / right movement with no binding. Perfect for off roading.
With ATV loaded up. I took this to TN from Fl and it pulled very nice. No wondering , no bounce.
New Pressure treated plywood with Tie down eyelets.
Built in tire carrier.
2000lb springs, 3500lb axles, Pro Comp springs, 31 x 8 x 15 tires (less than 2,ooo miles on them)
