View attachment 295174 havent seen much out there except this Jensen . Has anyone used this radio ? Any other suggestions?
The insides are coated to protect it from dust and it’s supposed to be able to take a beating says it’s normally used in tractors excavators and such lol .What makes it heavy duty?
Best suggestion I’ve heard so far lolHead units are very inexpensive now days. Just install one at a third the price and replace it when it dies in 5 years.
Beware of the super cheap head units, though. You expect lower build quality and probably higher distortion, but some of the features aren't what you expect. Here's some examples:
If you go for a Pioneer, Kenwood, Sony or other real brand, these features are generally implemented as you would expect and therefore you can actually use them.
- What looks like a VU/Spectrum display, but it actually just moves in the same pattern all the time, regardless of what is playing or if anything is playing at all.
- USB drive playback that doesn't allow search or playback by album or folder. Basically all files are treated like they're in the root directory and the only way to navigate is to skip by 10 tracks at at time. Super sucky when you have thousands of mp3 files on it.
- Shuffle mode that isn't actually random, but plays the same sequence everytime, sometimes never playing 1/2 or more of the tracks. I've seen one that starts over on this same sequence every time it's powered on.
- Bluetooth that doesn't automatically pair. Sure it does bluetooth streaming (eventually), but you have to manually pair it everytime you start the car. When it stops accepting the pairing you have to disconnect power to the unit.
- FM tuner can only grab the strongest stations. Will not have AM.
- I've heard of some that are super quiet - like at max volume you can't hear the music.
Been around a bunch of the Jenson truck/tractor radios myself. Good, tough radio for people who don’t care about pre-amps (whatever they do) etc, etc.The company I work for had a fleet of tractors that were equipped with that radio. I really liked them. They were very easy to use even while bouncing through a field, they got good reception and they even told you the song that was playing. I don't know the power output, but they sounded great to my ears in a tractor cab with four 6.5 inch speakers.
