Fabrimacator21
I did the "posi" check on the heep a while back and I'm still not sure If it has posi or not. I had both covers off front and rear diffs and It didn't look like it had posi but once I put the covers back on and jacked up one tire (pass front) it wouldn't spin freely. It would only spin with a torque wrench on a lug and it "felt" like there was a clutch in there. I didn't see any springs or clutches but it definetly takes a serious amount of force to turn one tire. Would I be able to turn it if it had posi? It also acts like it has posi but I'm not sure if thats just the all wheel drive. It'll lay down rubber tracks from all four tires on concrete just going around a turn. When in low it will just screech tires on asphalt/concrete.
