Working through the tune up of the engine in the truck, something I do with all used vehicles I buy. Next step is the ignition. If the condition of everything else on this truck is any indicator, the distributor is probably original from 1984. So I was curious if there is any benefit to getting an upgraded distributor or if there is a particular model(better spark or more reliable or whatever else) or just sticking with an oreilly's replacement. Was also going to throw some new plugs and wires at it while I'm at it. Engine is just a standard 60 over small block with an RV cam.
