This would be your basic non-computer HEI, ca. 1976, with a 4-pin module.
I assume that since there's no crank position sensor, that I can rotate the wires anywhere around the cap, as long as I keep 'em in the right order?
I'm trying to adjust the timing after swapping the dizzy out, and I'm reaching the limit of turning the thing to get it timed... so I figure if I can rotate the wires around one position, then I can get it set.
Or is there a specifc post on the cap that has to be cylinder #1?
-- A
-- A
I don't think my trucks would ever run
Scott was kind enough to get the dizzy set up so the motor actually fires again -- he has some magic trick to get the dizzy to set wherein he pulls a Chuck Norris and just wills the oil pump slot to move
