Plugs are plugs. Iridium's and what not appear to be the "norm" anymore, but for our engines, buy the AC Delco replacement that is spec'd for your engine.
Electricity ALWAYS takes the path of least resistance, all E3's do is shroud the spark from the mixture in the cylinder. If they were good, the OEM's would use them. E3's have been out long enough that were they as good as advertised, every OEM would be using them. They are not. That tells us everything we need to know.
Multiple/crazy 8 electrodes MAY help on an engine that burns oil and fouls plugs, but the solution isn't a high dollar plug. It's to fix the problem.
You can even go crazy and gap the plugs from .035"-.080" (all factory HEI specs BTW), guess what? No difference in power, mileage, or drivability if everything else is working properly.
