Anyone who is running "stock" springs, that are preferably very new, can you measure the height of the truck from the ground through the centerline of the rear axle up to the edge of the wheelwell? Same for front might help too.
I swapped out my old leaf springs that had an add-a-leaf in them for some newer springs that appear to be a stock replacement. I ended up gaining about an inch of lift. Not really the look I wanted, especially since the front is now lower by about an inch.
I'm curious what a basically stock truck sits at. With my 33's on stock wheels, I'm right around 38" now.
Eventually I plan on new springs all the way around, but I'd like to know if the front will end up raising as well, or if I just ended up with some springs that aren't quite stock now.
