Height ?
Just so it's clear.
You have a truck with a lift and little bitty 28 inch stock tires. The frame at the crossmember is 23 3/4 inches off the ground.
I have a stock truck with little bitty 28 inch stock tires, and my frame at the crossmemeber is 15.5 inches off the ground.
That means you have an 8.25 inch lift, which you know you don't have.
Is this correct so far?
Yes you are correct so far. Except I don't have tires on it. Sitting on stands at a set hight. When it had 7" of lift it sat higher than it does now. I am thinking 5 to 6" of lift as it sit now. Your 88 is a square body?
I was not figuring the radius difference in the tires. :doah:So I have it set at 4" of lift. Thanks for the help.:waytogo:
