I have way worse spindles than that on mine and the new style seal sealed no problem. Agree to clean it up a little smear on the rtv and call it good. I fill mine to the fill hole and send it. Only hubs I've ever added oil to were big truck hubs.
Yeah, I pulled the tube and checked it, then stuck a wire down into the housing just to make sure that wasn't plugged.is the vent open and flowing air free ...... this can cause any axle to puke oil out were ever it can .
Good idea on the swap. This 14b has 456 and a Detroit, so I'm not ready to give up.Could cut bait, grab another 14b.
youre sure the hub is properly seated on the spindle?
Curious - have you tried swapping wheel hubs to the other side and seeing if that same hub leaks when on other side and if the other hub leaks on this side?
