Help 81 K5 wont Start!!!
jghall
Registered Member
Conyers, GA
Need some quick help... Took the K5 to the spray car wash yesterday for a little undercarriage degreaseing... I covered the carb, distributor etc like I always do... Got the job finished, removed all the covers, replaced the breather etc, jumped in the Blazer and drove home... Drove several places the rest of the day with no issues... Now this morning, I go jump in the blazer, hit the ignition switch, the starter clicks and then I loose all power to the Blazer, Lights, horn, clock, radio everything... Wait 10 min and all accessory power is back... Hit the ignition switch and the same, starter clicks, then all power to truck is gone... Im thinking starter solenoid, what do ya'll think??? Thanks for any help...
Battery is good. Im thinking solenoid too. Thanks for the reply.
Sent from my ATRIX using Tapatalk
It's almost 100% the connections. Check the battery, starter, ground. All the wires. My dodge wor do this with 13 volts in the bats. Wiggle the main power on the driver battery and I could get it all back!
Checked all connections and no change... Went to the parts store and bought a new solenoid ($10.99 :D), she fired right up... Thanks for the help guys... :waytogo:
