badmix
.........in the down position. How do I get the window up. the cable broke in the middle and I was able to pull it out , the blue outer sheath is still there, but I cant access the end of the cable that goes to the window regulator nor can I get to the regulator because the glass is in the way.
I removed access panel but that only exposes the motor. How do I get the window up til I can get a cable and where is best place to get the cable??
1984 K5 if it helps any.
