gerber boy
Registered Member
hey fairly new to the forum but been reading for a while i have a few question hopefully i can get answerd, i've got a 77 k5 with dana front and 12blt rear and 3.08s, 350,th350 and 203. so far i've redid the top end with rebuilt heads and alum intake, (truck came with a cracked head and a warped one). i'm currently swaping to a 81 front end, from my parts truck thats torn down.
I plan on swaping out the dana with the 3/4ton out of the parts truck. (10bolt with 8 lug outers and 4.10's). swapping the 205 into at a later date. and putting the 14sf in the back(limited slip) at the same time. and possible later on putting the 4speed into the truck too.
no my questions,
I plan on mostly playing in the mud, on some trails and snow. there is not a lot of rock around here. but i also drive it on the street and there will be highway.
1. i orginally planed on running 35/12.5 bfg mud terrains or swamper tsl's but i came accross a set of 38.5/11 boggers for decent price, will this be too much for my gears or axles?
2. ive seen add's that say lifts from 73-76 and 77-88 is there a difference? cause i found a good deal on a 4" thats barly been used (4"springs and add-a-leaf and block) that was on a 75.
3. will i need a raised steering arm or dropped draglink with only a 4" lift?
thanks guys.
no my questions,
thanks guys.
