Help an idiot - which way does the fresh air diaphragm housing attach 1991 K5
Jessie James
VA
Thinking I knew what I was doing (always a mistake) I removed the fresh air control diaphragm from the passenger side kick panel, did what I wanted to do, and now when I am going to put it back I cannot figure out which holes it bolts back to. Help me out?
This picture is shot from the drivers seat through the glovebox opening with the glovebox removed.
There are 5 screw holes in the panel, so let's start at #1 at 12 o'clock, #2 at about 2 o'clock, #3 at about 4 o'clock, #4 (obscured) at about 7 o'clock, and #5 at about 9 o'clock.
Then the diaphragm has two holes, one on each end of the rod, so #1 at the top of the photo and #2 at the bottom left.
Which holes does it go into?
THANK YOU! :D
THANK YOU! :D
Just looked at my 85 and the medal tab #2 goes to the 9 o'clock location and the #1 to the 3 o'clock
