The Pumpkinator
I just did a disc swap on my 14 bolt and my rear brakes drag, is there a valve or something that can be adjusted to release pressure to the rear calipers?
I just did a disc swap on my 14 bolt and my rear brakes drag, is there a valve or something that can be adjusted to release pressure to the rear calipers?![]()
There should be a proportioning valve next to the brake booster, at least there was one on my Dodge. If not, the perhaps you are going to need one. Check out Summit Racing for one.
LT.
There is no adjustable proportioning valve on these trucks.
You will probably need one, but that is a different issue.
Lack of proportioning room won't keep the calipers from retracting.
If you are using the caddy calipers with the brake, the brake caliper piston is kinda threaded, and has to be "reset" back into place with a special tool when installed to work properly.
If your truck was drum brake from the factory it will probably have a residual pressure valve/proportioning valve next to the brake master cylinder.
this is correct. factory disc/drum combination (proportioning) valves have a system that keeps ~2-10 psi in the rear brake line (so the brakes don't feel mushy).
Interesting. Would this give the sense of having to pump the brakes after the trucks sits? My brakes have long travel on the pedal just once when I first back out, then they are good. I figured I still had some air.
Stuff like this is why I didn't swap to discs right away when I put the 1-tons on. Of course, my brakes are still weird compared to the originals, mostly long pedal travel. Can't win I guess.
Long pedal travel? Not much brake action happening?
Had that on my Beaumont, ended up going to a bigger master cylinder.
