Hello everybody,
i recently installed a new camshaft in my 86 K5 blazer, I chose the "compcam 12-210-2"
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=73&sb=2
So the cam broke in good, and after the break in, I had to remove to heads to change my springs (I kept the old, softer springs to break in the cam) and after i put everything back, i timed it to initial 10 degrees BTDC, however, while trying to find TDC on compression, i noticed that I also had a small compression zone on the exhaust stroke, right when the piston is almost at 20 BTDC exhaust stroke. I noticed that the exhaust valve closed at around 20 BTDC, but the intake valve opens up only at around 5 BTDC, so there is that 15 degrees where both valves are closed and since the piston is on it's way up, there is a fraction of second of compression...(I can hear air comming out of the spark plug hole) I doubt that this is normal (or is it ??) there's no overlap, meaning intake valve starts opening while exhaust is not yet fully closed. Thing is, I don't remember having that small compression on exhaust stroke before removing the heads. Or maybe it did happen but i didn't notice, which would surprise me.
The cam specs says that:
exhaust opens at 68 BBDC, closes at 20 ATDC
intake opens at 28 BTDC, closes at 60 ABDC
but I don't have that at all, what I roughly have :
exhaust opens at 15 BBDC, closes at 20 BTDC
intake opens at 10 BTDC, closes at 11 ABDC
I read that roughly on my balancer, those are not precise values, but I wanted to have an estimation/idea of what was going on in my engine. I would understand if I had 5 degrees of difference between what i read and the official cam specs, but the difference I have is really big
I'm lost... did comp cam mislabeled their camshaft and they sent me a wrong one ? Would they make such a huge mistake ? Or did the timing chain skipped a tooth ? but Timing chain, crankshaft gear, camshaft gear are all new... and even if it did jump a tooth, it wouldn't change the specs that much !! So i really don't know...
I need help !!
Thank you !
I need help !!
Thank you !
