BACKGROUND: I'm having a bit of a problem with my GTO. The motor has about 9K miles on it and when I rebuilt it, it got a new cam and lifters. It has the stock rocker arms and pushrods.
SYMPTOMS: It just recently developed a tick pretty much all the time. Sometimes it's more noticeable than others. And, it now backfires under hard acceleration. I thought they might be unrelated problems. For the backfiring, I thought it might have a vacuum leak in the carb (vacuum secondaries) so I rebuilt the carb. It runs and idles a whole lot smoother now, but did not correct the backfiring.
Tonight, after it dropped below 100 degrees, I decided to pull the valve cover and see if any of the rockers were loose. The were all torqued down tight, but my last lifter was loose and couldn't be tightened any more. The pushrod isn't bent.
DIAGNOSIS: The lighting sucks, but you can see the rear rocker not really moving as much. I'm thinking it's either a worn cam lobe or a bad lifter. Here's a video of it running. What say CK5?
--the snap ring had flew out,and allowed the lifter to pump up too high ,and evidently the "cup" was able to jump out,yet not let the pushrod fall out of the lifter!...
