COCHEV
ok, picke up a used burb with a 454 with the "supposedly" rebuilt motor with a decent cam. anyways, it idles rough and misses. i was told it had a healthy cam. the miss seems consistant through out the rpm range. soooo, routine checkout shows this...
about 10-11" vac
dry comp test-
1- 100
3- 110
5- 110
7- 115
2- 110
4- 118
6- 110
8- 118
timing was very advanced 18-20ish (off the timing tab) but i've read 454s with larger cams run this way. i tryed retarding it to 12degrees and it ran worse- bogged and popped off idle
cap and rotor was well worn so it was replaced
plug wires were touching the headers so they were replaced as where the plugs. some plugs looked a little black, but not bad.
so could the one cyl. that is only at 100 cause it to run like it misses? could the coil be going bad? thanks
about 10-11" vac
dry comp test-
1- 100
3- 110
5- 110
7- 115
2- 110
4- 118
6- 110
8- 118
