Help - ECMB fuse blows in 91 Burb
Eric M.
Oakland, CA
1991 Burb, V2500, 350, L480E, all stock.
Went to start, cranked, but would not turn over.
Found ECMB fuse was blown (10A), replaced w/ 10A.
Burb started fine, let it run in driveway, about 10 min. later it died, fuse blew again.
Installed 15 amp fuse, let truck run in driveway for 2 hours, no problems.
Went to start this AM and fuse was blown again. Installed another 15A fuse.
Truck started and ran fine.
I'm assuming this is an intermittent elect. short in one of the components on the ECMB circuit and will be next to impossible to chase down as it seems to happen for a very short time (long enough to blow a fuse) and them goes back to working correctly.
Before I pull out the shop manual and elect. schematic and spend the better part of the next week trying to diagnose this problem, I thought I'd ask if anyone has run into this before.
Thanks,
Eric M.
THE FIX There was a short in the ECMB wire. It would only short for a split second, enough to blow the fuse, then go back to working fine. Made it difficult to track. I tried changing every component on the circuit, then drive and wait. I'd get a week to a month and the fuse would blow. Stick a new fuse in and I was good for at least another week. I bought a box of 30 fuses and figured sooner or later it would short and stay shorted. It did finally. I pulled everything off the circuit and it still shorted. I then cut the wire on the back side of the fuse panel and no more short. I ran a new wire from there to all the components and the truck started. Just for kicks, I reconnected the cut wire, and it did blow the fuse again.
I have no idea where the short is and am not going to unwrap a mile of spagetti under my hood to find it. But, I will say, there is no obvious place where it could be grounded out. The wiring is all stock and in very good condition. It's all very odd, but as long as I don't have to carry around a box of 10 amp fuses anymore, I'm happy.
Eric M.
pull the air cleaner off, and make sure the wires going to the injectors are not pinched under the air cleaner. very common for this to happen.
I had the same problem a while back. One of my wires (oil pressure sensor wire IIRC) had chafed and was intermittantly gounding out which in turn blew the fuse. I replaced that section of wire and it has worked fine ever since. I'd do a quick check of your underhood wiring harness to make sure this wasn't the case.
I can't remember the answers but this fuse has been well covered in the past so a search should throw up what you need.
After 6 years and 2000 posts, you'd think I's know better. Yep, that searchy thing really does work, got all sorts of leads to follow.
Now all I need is a little motivation to get started.
Thanks,
Eric M.
Check the fule pump that was my probelm. I replaced the pump and wiring and have not had a problem sence.
Thats the first thing I thought too. If the pump is locked up it can cause that fuse to pop.
Yeah do a search ya Newb:wink1::haha:
Im having the exact same problem with my 91 K5 started happening after i replaced the fuel pump and wiring harness, but i cant find a short in any of the lines.... yet
You might want to make sure that you did not pinch the wires between the frame and the gas tank after you replace the fuel pump.
word of advice open up the floor with a cut off wheel its easier to do than dropping the tank I just tow my burb home this morning with same problem will check and change pump this week had to change pump on my K5 few years ago way easier to go in thru floor then put in a hatch from a patch panel
