adam9716
Registered Member
I have a 1980 k5 with an 87 350 tbi. While the engine idles the rpms surge from high to low, and after the truck warms up it goes away. After I let it warm up and the surging stops I put it into reverse and the rpms go way down like its going to stall, but comes back by itself. When I press on the gas while in drive the rpms also go way down, and if i keep the pedal pressed it'll stall. I have changed the rotor, cap, fuel filter and spark plugs. What would be the most likely cause of this type of problem? fuel pump? Please help!!!
