bpgardn
Registered Member
The blaze is still down. Does anyone know where I can find a clutch pedal assembly unit. I have a 1989 manual k5. Im told that the rod from the master cylinder is warn almost in two
the guy fixing it cant get the angle he needs to weld and grind it down without pulling it all out.
And will a 1979 suburbans cpa work in my 1989???
Thanks for any help.
the guy fixing it cant get the angle he needs to weld and grind it down without pulling it all out.And will a 1979 suburbans cpa work in my 1989???
