Help fund my 77 build! PLEASE
original balzer
roosevelt utah
Ok first up on the chopping block.
1979 GMC crew cab. This only includes the cab front clip and frame. The frame has been shortened and semi converted to 4x4. this leaves a SHORT section for a 4ft bed. This cab is mostly stripped and the dash has been cut out leaving the vin tag. I will throw in what ever extra parts I am not using.
I am asking $300 or best offer and I am usually pretty open for trades.
steering col not included but i will throw in a non tilt.
frt clip
this is what it looked like
minimal floor rust. Should be an easy fix.
next up is a running 6.2 PLEASE NOTE I do not know how good of condition this engine is in. It was swapped into the 79 by the previous owner. The glow plugs where NOT hooked up and ether was used to start it. Witch to my knowlage is fine as long as the glow plugs wasnt working.
I do know that it ran good and didnt have any noises or smoke.
Im asking $300 OBO as well. I have a non running 6.2 as well that could be thrown in.
I will add more later its late.
I dont remember witch is witch but they are both the one with the more restricted intake. or less desirable one if you will.
BY THE WAY both 6.2's have standard trans flywheels.
