help help help front alignment
RESTORE89
CHAS SC
alignment shop says no way to adjust camber and caster only toe
dealer says no way to fix
i can not believe i am the only person to own a K-5 that has alignment issues
i ask the dealer "well then i guess they make the trucks to be disposable since there is no way to fix the alignment?" his reply, "uh uh uh no i'm not saying that"
some one please advise
thanks
chris
It needs a bigger motor.
what's in it now?
doen't matter it NEEDS A BIGGER MOTOR
89 350tbi/700r4h/np208/4.11's
There are shims that can be installed behind the spindle to correct your alignment. My K30 uses them and I've seen them on a 3/4T. I'm not sure where to get them though. You could try calling some good alignment shops till you find one that knows what you are talking about.
Good luck.
Caster can be adjusted with tapered shims between the spring and axle. Camber usually has no adjustment on a straight front axle. Typically there is nothing to "wear out"(other than ball joints) so these settings don't change unless something is bent or modified. Lifting the truck will not change camber so it shouldn't need adjustment.
Michael
<a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
