Stumpuller
Registered Member
hey guys and gals. Ive got a bit of a problem with a non-blazer side project of mine.
Ive got an 82 2wd S-10 with a 350/350 turbo combo. its been a bit of a never ending project for the past 4 years. but I want to get it together this summer.
The first engine i had in it was a worn out 80s 350 (from a blazer
) with the dipstick on the passenger side and i used the stock exaust manifolds. It eventually did its best handgrenade impression and had to be pulled. I got another engine from a 71 chevy 3/4 ton and did a quicke on the bottom end just for kicks. its a good strong engine. ... but now with my 80s manifolds the drop on the drivers side is right in front of the dipstick hole on the block deck. ive got a pinched off tube to plug the hole now because i just wanted to get it running. but now i cant check my oil and im very broke these days and it is new exaust so i dont want to chop it for differnt manifolds.
can i weld a tube into the oil pan sump for a dip stick?
any ideas?
) with the dipstick on the passenger side and i used the stock exaust manifolds. It eventually did its best handgrenade impression and had to be pulled. I got another engine from a 71 chevy 3/4 ton and did a quicke on the bottom end just for kicks. its a good strong engine. ... but now with my 80s manifolds the drop on the drivers side is right in front of the dipstick hole on the block deck. ive got a pinched off tube to plug the hole now because i just wanted to get it running. but now i cant check my oil and im very broke these days and it is new exaust so i dont want to chop it for differnt manifolds. can i weld a tube into the oil pan sump for a dip stick?
any ideas?
