Burn-N-Daylight
Registered Member
Let me start off by saying i have been lurking around this site for a week or two before coming a full member. I recently moved to denver from washington state. So i decided to buy an 85 k5 with a 6in lift with 35x12.5 with a 350 nothing special. i recently bought an 83 thats been rolled i needed the motor since the crank had snapped in my 350. so i dropped in a 305 last weekend which ran great in the other rig but for some reason or another all of a sudden it will start up and it will sit at an idle for 10min and then it will shut off with out any warning. so i replaced the dist. coil i had voltage going to the coil and no power coming out. i pulled a plug wire off to see if i was getting spark and i had none. when i went to start it with a meter hooked up i had a voltage drop (9v) it does have new wires,plugs,cap,rotor, and new coil. it will just turn over and not start if i let it sit for a few hours it will start and then die shortly after. so i am at a loss is there any thing that i am over looking? any advice would be much appreciated. Thanks in advance
James
James
