Hi, I pulled my gear box to replace the input seals and the sector shaft seals. At first I didn't install the O ring on the worm gear shaft since I was afraid to open up the front. Well, after install it leaked around the collar while I bled it so I yanked it again. I had no problem (should have done it first) pulling out the worm gear and replacing the flat, cracked O ring. I was careful to put the cap back together right.
So I installed it (again) and proceeded to bleed it (again) and while spinning the wheel, the gear seemed to snag or bind. I figured it was due to the fluid getting back in there so I continued to turn the wheel (slowly and gently) and I heard a clunk and the wheel spun freely. I rotated the wheel the other way and it did the same thing. Now my steering wheel just spins freely. I can grab my tire and turn them ok from there.
Something must have happened when I reinstalled the worm gear. Any ideas?
If it helps, when I originally reinstalled the sector shaft, the teeth in the gear box had rotated down and were unable to align with the teeth on the shaft, so I spun it back up so the shaft would go back in, then it worked fine. Could this have happened again somehow when I pulled out the worm gear?
