Plan A: Just get a small drill bit and drill out the center of the bolt (or whats left of it) and then get a cold chisel and try to collapse the sides inward.
Plan B: Drill out the bolt completely and rethread it. If you get the right size bit, just a tad smaller than the bolt your taking out, you might be able to save the threads.
Plan C: Spray PR Blaster around the bolt, drill a small hole into what is left of the bolt and then pound something inside the hole and try to unscrew the bolt that way. Similar idea to an ease-out just more violent. lol.
Plan D: Take it machine shop or autoshop to get it out and pay out the azz.
Plan E: New Intake manifold (just be sure to upgrade to a performance one) , if this is the case, spray all your bolts with PR Blaster and let it sit over nite.
