I'm guessing (link in my signature will take you to the GM wiring manuals) that it is indeed the ALDL wiring. If you look at the ALDL connector, you've probably got maybe 4 actual wires running to it? It's been awhile since I looked at one, but there aren't many there. IIRC for the TBI trucks, TCC is one pin, ALDL data is one wire split to two pins, and a ground? I believe on the ABS rigs one pin might be that as well.
But as always, the wiring diagrams won't guess.![]()
