Help identifying parts
TJ1978
I have MANY questions
East Valley, Arizona
just finished going through all the boxes of stuff that came with the truck. Some of these items I don’t know what they are, some I have a hunch.
1969 c10
I believe that second one may be an original trans stabilizer bar that goes between the bell and tcase. Also the othe bracket may go with but I'm not sure as my 70 no longer had it. Next is hvac fan switch, oil pan distribution bars, #9 for torsion boxes, #10 goes on the driver inner fender to support behind the steering shaft, 11 maybe bumper mounts?
1000 piece jigsaw puzzle!
Pic 1 and two Alternator brackets
Pic 4 Heater fan control
Pic 5 Goes on the engine oil pan
Pic 8 Rad hold down at top of rad support
Pic 11 Bumper brackets front or rear?
Yea now lookin at it thos brackets are smaller than I thought probably go with the alt bracket. I should just shut up lol
Looks like a TH400,I see what looks like the vacuum modulator on the right front side ..no madulator on a 700R4,a TH350's modulator is on the right rear side,next to the tail housing.
There was more cat hair trash that anything...
I made a pile of throw away stuff. But I may just hang onto it until this truck is running, you never know..
Thanks for the help...
I’ve heard of the th400 but never have seen one. I know it’s not a th350
I’m more concerned with the above parts...
#6 oil filter canister
#9-10...maybe fender to core support, or fender to front grille valance.
I’m going to start a thread once I get everything identified and sorted... I wanted to get these first few questions dialed then start it. I figured these separate threads would get more attention.
Probably tomorrow I’ll do it
@Bent77
My Vette came with one...kinda PITA to get the square oring seal in and the edges of the canister to seat perfectly on the seal.
Used the later model spin on adapter!
