twiget
I'm finishing up a gear change on the rear end of my 'burban. It is a 14 bolt 10.5" rear end. I got everything adjusted, and was doing one last check to make sure everything was working well, when I noticed this on the bottom of the housing:
(quarter for size reference)
Until I found this thing, I was 100% sure that I had put everything back together correctly. Now I'm ~98% sure. It is magnetic, and it was at the bottom of the housing, which leads me to believe that its purpose in life is to suck up any metal shavings as the gears wear in. The only thing holding it in place was the force of the magnet though, which kind of disturbs me. If that thing came free, that would be the end of my new gears...
Any thoughts?
Any thoughts?
