DizturbedOne
77 GMC Jimmy... I've been trying to get a job I have a line on for TWO DAYS but I have no transportation right now because of this!
After they tried to get it, the inside of the cylinder just pulled right out in my hand when I pulled on the bezel, key and all. So now the inner guts of the lock cylinder are stripped out, leaving only the sleeve inside the column.
Today I find it's the kind with the tab I need to depress to pull the sleeve out. Upon every attempt though, it will NOT let the sleeve slide free. So I dig up the book and it wants it in "off" to do this. Without any inner part of the lock cylinder (the whole piece the key would ride in) I can't interact with the sleeve itself in a normal fashion, although I can get the ignition to change positions via the wheel lockpin. Whatever position I try it in I can't get the sleeve to slide out at all.
I'm not sure I'm doing this correctly or why I'm having such problems. It seems like it should just pull out at this stage. Has anyone run into this problem before? Figured it out without having to pull the whole column apart? I'm a little intimidated at pulling the whole column apart, and right now I can't afford to buy anything I might break. So I'm taking it slow and trying again tommorow after poking around on here. Any help would be GREATLY appreciated, you're literally helping my family on this.
