help in alberta
diaric
Registered Member
Bentley , Alberta
New member here. restoring my 87 Jimmy, parted out the 2 previous ones.
I see quite a few of you here from Alberta rebuilding 6.2 diesels. I have 2 junk blocks already with bad web cracks and was hoping one of you may have a line on a half decent block to rebuild. Rebore isn't a problem. I haven't had much luck finding something good. Any I find at the wreckers, they want to charge you like its a rebuilt block if its running, and it will probably have cracks if its opened up. thanks in advance for any leads.
Welcome to the forum!
I don't have any lines on engines for less than $1000 here in Alberta, but you might try hitting up CK5's own Byron aka Wrench. He has a 93 6.5L block kickin' around at his place that has one small crack on one of the mains, but not in a place where you'd need to worry about it.
Last I heard he was thinkin of using it as a builder, but I imagine that if you gave him a good offer on it, he'd be willing to let it go :)
BTW, why not post some info about your build? Not just the engine either, but the whole rig! We love pictures and any details you are willing to post!
