I am in the process of restoring a 1987 R10 LWB with a 305 TBI ... In my teardown process to remove the engine, I have been taking my time, photographing all wiring connections, bracket configurations, bagging and tagging bolts to the respective areas .. so I know 2 months from now where everything goes and i don't want to say where does this go. .. I did this with my 85 K5 Restore and I have used those pictures to help may others on this forum ..
When I was attempting to remove the TBI it was stuck to the manifold and instead of prying straight upwards, I used a small rubber mallet to tap it sideways like I have with a carburetor years ago.
I was busy and not paying close attention, but I swear when I lifted the TBI there was metal piece on the manifold between the bores. I could have been dreaming, but bottom line, I have no idea what or where this piece goes. and could it have fallen from something else on the upper part of the engine ..
In researching the various TBI, some have a different base molding between the bores, it appears there are two types... with one more prevalent. Not Mine.... I heard it called a bridge and an island . With the respective gaskets going to the different types.
This metal "Tit" is tiny, the base is six sided and the inside it appears to have threads ... and like I said ... I have no idea where this goes.
Any help would be greatly appreciated.
Also .. I see two gaskets in the rebuild kit and the most common question I see in blogs is which do I use ... I thought I could figure it out, but I am as lost today as when I started... so comments welcome here.
Thanks in Advance,
Rob
Thanks in Advance,
Rob
