Help locating parts source 1979 k20
obijuank5
1 ton status
Solutions
Central Texas
I need to find the clutch bellcrank ball and pivot bushings for a 79 sm465. These should be wear items and easy to get. Why can I not find them?
At this point ill take what I can get. This is for a restoration so new is preferred.
Dorman makes the stud ball that goes in the engine block for the cross shaft ,if that is any help..not sure if the one on the other end that goes in the frame bracket is the same as that one or not..if the cross shaft tube is egged out you may have to figure a way to re-bush it yourself..
Oh that's good stuff. Thank you for taking the time.
I might even have the parts you need sitting on my work bench... If I recall correctly I didn't use all of the parts, I'll take a look at whats left when I get home.
